Digitally measure angle of a rotating shaft.
sammcc
Aerospace
Jan 21, 2013
103
Hi all and hopefully this is the correct forum.
I need to design a test fixture whereby I will spin a 1/2" diameter x 10" long shaft at 2RPM
While the shaft is spinning I need to apply a force to the side of the shaft to achieve an angle between 3 & 3.5 degrees.
This is straightforward enough.
What I am wondering is there some piece of equipment available on the market that I could use to measure the angle of the shaft during rotation digitally, I could probably do it using some sort of engraved plate as a visual indicator but this is 2017 and I would like to do it digitally.
Thanks in advance for any help provided.
Hi Aidan, I need to explore rotary encoders further- thanks
Hi 3D Dave, yes, sort of. It is fixed at the bottom and pulled from the top to a 3degree angle
Hi IRstuff, the protractor I do not think would work as the angle needs to be measured while the shaft rotates.
?? What is being "pulled?" Is that part rotating as well? There has to be something that isn't rotating that allows you to push on it without generating infinite friction; that part can be attached to a protractor.
TTFN (ta ta for now)
The shaft is mounted at the bottom It is then rotated at 2RPM, The shaft is then pulled from the top to 3 degrees, this is what I want to measure while the shaft is turning. I need to be able to measure it while it is rotating to ensure that the rotation at this angle is smooth and consistent. I am replicating how the part will work in service.
To perhaps add a bit of clarity, it is a partly thin walled fabricated shaft that has some flexibility, it is not a solid bar, this is what I might have given the impression of.
Yes I am using a bearing as part of the device that pulls it.
hmmm- the inside of the bearing rotates but the outside doesn't so I may be able to potentially attach it as you suggest.
Thank you!
