sammcc
Aerospace
- Jan 21, 2013
- 103
Hi all and hopefully this is the correct forum.
I need to design a test fixture whereby I will spin a 1/2" diameter x 10" long shaft at 2RPM
While the shaft is spinning I need to apply a force to the side of the shaft to achieve an angle between 3 & 3.5 degrees.
This is straightforward enough.
What I am wondering is there some piece of equipment available on the market that I could use to measure the angle of the shaft during rotation digitally, I could probably do it using some sort of engraved plate as a visual indicator but this is 2017 and I would like to do it digitally.
Thanks in advance for any help provided.
