jheidt2543
I have seen round bar, cable, angles and tube sections all used as diagonal braces in building frames. Is there any reason that flat bars could not be used?
In remodeling an existing single story, 30' eave height building we plan to add X-bracing in some of the bays. Since the use of any "three dimensinal" brace installed on the column centerlines will require cutting or slotting the wall girts to install the braces, the question has come up regarding flat bar. The erector's thought would be to install the flat bar across the "face" of the girts and weld them to the inside face of the column flanges. Now, this would introduce some twisting into the columns since the connection would not be on the column centerline. The load would be (column depth/2)*(tension force). One solution would be to put the flat bar on both the inside and outside of the column.
I think this would be similar to the flat stock straps used to brace in light gauge stud walls, except that the loads will be higher. Generally, the flat stock is welded to each stud, would welding the flat bar to each wall girt be a benifit or a problem?
Any thoughts on this?
