geneiusxie
Aerospace
- Mar 10, 2013
- 52
I'm doing some research on whether investment casting would be a good way to reduce production costs for my company, but I want to make sure that the quality of the finished parts is top-notch.
NOTE: some of these questions are kinda noobish haha
How do you make sure the metal seeps into all the little crevices in a complex mold? Couldn't air bubbles form when you pour in the liquid metal - effectively displacing it? Does the ceramic material let air out or something?
Can you cast extruded metals such as 7075 aluminum and then heat treat them to be the same strength as an equivalent CNC machined part? Heat treating might be expensive, but it would still probably cost less than CNC machining.
What if sand particles get into the metal? Would that ruin its fatigue properties?
Would I need to put 7075 aluminum or stainless steel in an inert argon atmosphere for maximum strength?
What are the best tolerances I can expect? Wikipedia quotes 0.1mm or so. If I want to make a complex gear or other piece of machinery, I might need to do some finishing. 0.1mm might not be good enough.
