design category ASTM BTH
ukengineer58
182
Hi can someone list the design categories used for FOS on the material strength. I am reviewing some calcs and comparing them to Europeon standards. I believe there are categories A,B etc...
It's a bit convoluted when using the Nd factor, but if you just look at 3-1.3.2 [ASME BTH-1-2014] you can see the design philosophy:
For Design Category A lifters, yielding and buckling limit states have a factor of 2.0, while fracture and connection design use 2.4.
For Design Category B lifters, those values are 3.0 and 3.6, respectively.
thanks for the reply. I am based in Uk and we dont use that code. so was trying to compare a set of calcs with out limit state approach. So was trying to understand what category A and B would be. As all i have is 'designed to B' which seems conservative for the case we have
Design category B may be the conservative case, but a lot of lifting devices are reused (and abused) frequently over their lifespan, so cheaper to overdesign a little than to put the controls and inspections in place to justify A
just call me Lo.
thats part of my reason. these are one off lifts of a defined known weight. So there is not chance of reuse. its part of a demolition
Ah, yes. If it is a one-off lift(say, padeyes welded to the piece being picked) -- that's a perfect example of a category A device. Most demolition is a great candidate for that.
just call me Lo.
great thanks - thats confirms what i was thinking. thanks for your help..
