So I have this blind hole which runs into another through hole.
We are doing root-cause analysis on why a drill went too deep (into the back side of part, almost through) and it wasn't caught.
I observed there was nothing in the inspection plan that required any verification of the depth of the blind hole, to which I was challenged that there was nothing on the print that defined the depth of the hole.
This is interesting to me. We specify prints are to be interpreted per ASME Y14.5-2009, so I went back to that, and couldn't find anything that spoke directly to this situation.
The print calls the hole exactly like the simplified drawing below (i.e. 3.000±.015 typical).
Now, it's my interpretation that the 3.000±.015 dimension controls both the distance from the identified face to centerline of the cross hole and the depth of the blind hole (as marked up below).
However, our quality department seems to disagree with this. They interpret it as only controlling the distance to centerline (just "1" in the mark-up below), and say this dimension does not control the hole depth. When questioned about how they would like the part dimensioned differently to specify hole depth, they don't have an answer, as they agree there's no additional dimension to add (it would just be the same dimension a second time).
So my question is, how would the rest of you interpret it, and how to best define the two requirements? Would you add a hole depth callout?
