deflection of portal
oneintheeye
GB
what are the typical deflection limits for a portal with masonry panels?
Check with the Masonry Insitute... I like something in L/600 range usually - maybe even tighter.
L/600 or the gap between the masonry panels, whichever is less.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
My interpretation of the L/600 limit is that it is for beams or lintels supporting masonry (in other words, vertical deflection).
For a portal frame, I would limit horizontal deflection to H/300, unless sealant joints limit deflection even further.
DaveAtkins
What do you need the portal frame for if you have a masonry wall?
The Australian steel code, AS4100, recommends H/240 for industrial buildings with masonry walls.
SCI publication 252 has some suggestions for deflection limits in portals, for masonry its H/300
