dengebre
- Jun 21, 2006
- 49
I have a wood-framed apartment project where the framer wants to construct the shear walls in segments, and sheath them on the ground before lifting them in place. This introduces vertical seams into the shear wall. I understand that each wall segment will require an end stud and that the segments have to be fastened together to transfer the shear across the seam. My question regards the top plates and the sill plate: Do the horizontal plates need to be linked between wall segments for continuity?
