Why not try the "Reference" function? (Not sure in which version this was introduced.)
Create a standard Mathcad worksheet containing your common unit definitions, functions you have created, common constants, and save as units.mcd say. (You don't need to include any standard Mathcad units, functions and constants etc.) Then at the top of your standard worksheet template, include the following expression:
Reference: c:\Mathcad\units.mcd
(Obviously, you must point to the actual path and filename.) In Mathcad 14, this is accomplished using "Insert | Reference" from the main menu - not sure of the procedure in earlier versions.
This will have the effect of inserting all of your standard definitions at the top of all of your calculations. Also, whenever you update your units.mcd file with any new definitions, all your new definitions will immediately be available in all of your worksheets.
Hope this helps!
