Default Datum Planes
  • Thread starter Thread starter rjmcgill60
  • Start date Start date
R
rjmcgill60
Guest
Anyone know how to create the default datum planes in a model that's already started. I'm using build 2001/2004090. Thanks.
In 2001 the default datum planes are already there with the default template.
You can change the template by unchecking default template and selecting another. You can create your own and save it in Templates folder inside your installed ProE.
Israr
HELLO !!! I said after a part is already started.
add a co-ord sys & drag this above the 1st feature
drag insert here to just after the co-ord sys
add datum - it should add def dats...
Ed
insert -model datums- offsetsplanes 0;0;0 or any other values that you need.
If you do not have a coord system already insert one first
