Dec 16, 2004 #1 R rjmcgill60 Guest Anyone know how to create the default datum planes in a model that's already started. I'm using build 2001/2004090. Thanks.
Dec 16, 2004 Thread starter #2 I Israr Guest In 2001 the default datum planes are already there with the default template. You can change the template by unchecking default template and selecting another. You can create your own and save it in Templates folder inside your installed ProE. Israr
Dec 16, 2004 Thread starter #4 P proed Guest add a co-ord sys & drag this above the 1st feature drag insert here to just after the co-ord sys add datum - it should add def dats... Ed
Dec 17, 2004 Thread starter #5 P pedja666 Guest insert -model datums- offsetsplanes 0;0;0 or any other values that you need. If you do not have a coord system already insert one first
