Hi all,
I'm working on an assembly with a DC motor (24VDC, 30:1 ratio) where I cannot use a coupling on the shaft but still need to dampen the thing and I'm not sure how to choose the correct damper.
From a brief search I found this unit, and i was wondering if this type is a viable solution or I need to search for something else?
Can i find a handbook with rule of thumbs on how to choose the right damper?
Thanks,
SD
Thanks,
SD
