Having read every post on color code I can find in these forums hasn't answered my question.
NFPA 79 14.2.3.2 (1) states " White with Blue stripe for Grounded (current carrying) dc circuit cunductor."
Given a power supply (switching) is wired to 120VAC and the neutral is Grounded externally. If the power supply is internally connecting the output (24VDC) return to gnd is the White with Blue a requirement.
My contention is that the power supply is not floating and the DC return is connected to ground so the White Blue is required.
Their contention is that if the DC return is not directly connected to GND via a separate ground wire then the wiring should be all blue as per 14.2.4.3(3)
Whose right?
Whose right?
