The "Means this" portion of figure 4-32 (b) states that the datum translation modifier for datum B means "adjustable location within location tolerance".
1) Is this saying that the datum feature simulator can translate 0.1 in either direction?
2) If a gage was made for this part how much travel is allowed for the translating datum B simulator?
My understanding of datum translation is that it is used to make sure clocking datum simulators only stop rotation of the part and do not do the job of locating the part.
3) If, in figure 4-19, datum C had been modified at MMB in the hole position FCFs (∅9.2 & 4X ∅5.1) would the translation modifier not be needed anymore?
4) Same question for figure 4-32(b). If datum B had been modified at MMB for the slot position FCF would the translation modifier not be needed anymore?
5) So really, I'm asking if datum translation only gets used (or mainly gets used) when the clocking datum feature is specified at RMB?
Thank you.
Thank you.
