Yes. They do sometimes take a while to unfold. But now we are getting to the meat of the discussion.
RMB, MMB, and LMB do not enter the standard till 2009 so I'd say it definitely does matter which version the drawing is intended to comply with.
As for the feature of size issue I can see it both ways. Clearly there are opposed elements and the size (as well as form) are limited by the profile tolerance . But does the phrase "associated with a size dimension." on the end of the definition mean a +/- tolerance? I don't know. If it does that would mean a cylinder controlled with a profile tolerance is not a feature of size. Following that how could you use it as a datum? How can you treat something regardless of feature size that is not a feature of size? And as Jim said above there is no guidance in the 94 standard regarding datum modifiers when the datum itself is controlled by a profile.
The 'extension of principles' mentioned above would make the fos issue moot. And a slightly further 'extension of principles' as regards the profile limits would make the RFS, MMC, LMC as it relates to a profile controlled datum feature, in the 1994 standard, moot too. Just how far anybody is willing to extend his/her principles is up to them.
