Custom Hole wizard profiles
btcoutermash
Industrial
When you add a custom profile for a tapped hole to the hole wizard custom data base, how do you get the callout to show on the print when you use "Add a hole callout" command??
SPR 231247 - Thread type, depth, and size is missing from hole callut for derived standards.
Till this is fixed you have to do it manually.
FYI - You did place the data in your "Thread data" DB and not just under Hole wizard... didn't you?
Scott Baugh, CSWP [pc2]
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Yes i did place the info in "thread data".
