curved washer 1
hotiron
79
Hi all
I can wrap geometry onto a curved surface or extrusion. How can I cut and leave the wrapped sketch?
The wrapped sketch isn't actually created when used in a Deboss or Emboss feature. If you want a representation of the wrapped sketch, try using the Scribe option.
If you explain what you are trying to achieve, we may be able to give a better answer.
[cheers]
CBL
I am trying to model basically a curved or bowed washer. (a flat washer formed into an arc to act as a spring) Ive extruded the partial arc and were trying to use warap to get the form I need, but cannot trim sections outside of the form.
Why not create it the way it will be created in real life ... as a Sheet Metal part with a sketched Bend?
[cheers]
CBL
I'll have to play with it as I dont use sheet metal tools much. Ill research what I can and any tips would be great.
Here's another curved washer model, with configs for normal and compressed states.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of Eng-Tips Forums?
 http://files.engineering.com/getfile.aspx?folder=cf94cab8-0e43-424c-bb82-f827b4e039a1&file=RTS_WW_Single_Wave_Spring_Washer.SLDPRT
