Curve through X & Y value in excel
rocket100
GB
Hi Guys,
I have a x and y value in excel sheet and I would like to make a curve from the date. Please suggest any advise.
Thank you
regards
Rodney
Hi Rodney,
What NX version you are on?
Best Regards
Kapil Sharma
Hi Rodney,
In that case first of all you can save the excel sheet in a tab delimited format (for example i saved it in .txt format).
Now go to file/Import/Points from file and import these points (it will create a seperate Group consisting of all these points) and the use INSERT/CURVE/FIT CURVE/FIT SPLINE and select the Group to craete a spline.
Bestr Regards
Kapil
That being said ....if you wish to drive the curve and points associatively (automatic update of spline everytime you change the values of co-ordinates or change the number of points)referring to the external excel sheet then i couldn't think of an OOTB but surely we do have VB programs (you can refer to some old posts in the forum as lot of expert comments have been given on the same ) for that or may be Knowledge Fusion (i have written one myself some years back but it is in NX7.5.).
Thanks and Best Regards
Kapil
Thank you Kapil, It worked great.
regards
Rodney
