Digging deeper...
I'm still trying to get a feel for what is industry standard...
I've contacted the manufacturer used for this project (a well known manufacture may have even been mentioned previously) and so far the information I'm trying to get seems to be difficult to get a hold of. Part of the problem seems to be that the shapes are proprietary so they don't want to give you the full geometry of the section. When asking for the section properties, they can give you S and I and c (section modulus, moment of inertia and distance from N/A to extreme fiber) for the shapes but they don't provide (atleast not commonly) J and C.w values. I also politely asked about talking with thier engineer and was told that is basically impossible (not saying that the people I was speaking with weren't very helpful, they were).
It seems as though if you use the 2005 (allowable stress method) of Aluminum Design Manual (ADM) you only need J. From talking with the manufacture they seem to calculate J for tube and Channel section just using basic approximate formulas ignoring the 'kinks' in the shape and using an average thickness. I kinda feel like I'm trying to uncover some secret society.
So below is where things are at and I'm curious if anyone can say hey your overdoing it or you're on the right track.
1. Checking mullions: First check the tables provided by the manufacture. To me these are a bit misleading because they don't really determine where the horizontal mullions are applying point loads, however maybe they are conservative. So you could check your height and spacing and if you are withing the limits then you're good. You still however may need to check your horizontal mullion for lateral load as these may not be in the charts. So it seems c, I and S values are provided somewhat readily. So you can check deflection, but now what about strength. Well you you would need J and if using 2015 ADM you many need C.w. Now the question is what is the standard level of analysis used. I see a number of ways this could go - (1) The manufacture provides detailed geometry and we calculate the section properties. As noted previously I think they are hesitant to do this given the proprietary shape. (2) The manufacture gives you all the required values (check out ADM illustrated examples curtain wall and you will see there are many variables). Also my experience thus far has been like pulling teeth. (3) You estimate the the sectional properties neglecting the kinds/bends. This currently seems like it is done. (4) You are within the range of the charts and it is likely strength (at least LTB) is not a concern. Check other limit states (i.e. local buckling, section strength). Maybe use this in combination with option (3).
2. Checking fasteners - I was told that the charts do not consider fastener strength. Therefore the screw/fastener properties need to be obtained from the MFG. Or the the allowable loads. This has actually been a somewhat difficult task as well however I believe I know have this information. It would be nice if they provided an allowable load as this again is a long calculation (Although I refer the reader to AAMA TIR A9 for info.
3. Anchoring to substrate - this seems to be the most straight forward as I get to select the anchor.
4. As Glass had mentioned think long and hard about your fee and willingness to get into curtain wall design. I haven't even started on some of the other considerations that other submittals that I reviewed seem to have overlooked or discluded.
Any comments are appreciated. Thanks!
EIT
