gio1
Automotive
- Jun 28, 2003
- 83
Hello
I am doing some dynamic analyses (with Abaqus/Explicit) to correlate the crushing of an extruded aluminum cylindrical tube with experimental results.
The tube is mounted around a steel rod (assumed rigid) with no clearance. It is supported rigidly at one end and is impacted at the other end by another steel tube (assumed rigid) of a certain mass and speed.
I have managed to (almost) match experimental results in terms of forces, acceleration and displacement, but there is a fundamental difference with the experiments.
Experiments show that the crushing causes the aluminum to fold several times over itself around the tube ONLY ON THE END WHICH IS SUBJECT TO THE IMPACT. The crushing stops halfway through the length of the tube and the remaining part of it remains perfectly straight.
Analyses show that as the crushing progresses the tube folds alternatively AT BOTH ENDS and eventually a straight section is left between the folded ends.
I have tried analysing the tube starting from several different pre-buckled meshes and also from an underformed shape (perfectly cylindrical), but I always come to the same conclusions.
Given the symmetry of the problem I would expect analysis results to be correct. So why the experiments show that the deformation takes place only on the end which is subject to the impact??
Gio1
Gio1
