CRN approval with non ASME materials 2
manaliac
17
Hello everyone,
I am working within a European Company which manufactures pressure vessels as per European Standards (EN 13445-3). We would like an approval for CRN.
However to my knowledge, not all Provinces accept "design + materials" as per European Standards.
We will follow then the ASME Section VIII Division 1 as the design code, but can you please confirm if it is mandatory to use ASME materials (with a clear reference)?
Thank you!
Section 8 Division 1 clause UG-4(a) states that all materials must be listed in Section II.
Table UCS-23 lists all the permitted carbon steel materials. There are similar table for high alloy, stainless, etc.
Contact the specific Canadian jurisdiction as soon as possible. They will be able to guide you further.
Yes
Mike
See if the material is dual rated. A lot of times it is and can be used for ASME, especially common materials.
Hello everyone,
Thank you All for your answers. We will probably end up with Dual use materials in order to still manufacture in the European Market as well.
UG-10 (1)(a) allows indeed other non ASTM materials, but the set-off list of conditions is quite similar to procuring a dual use material.
Why don't you buy only ASME approved materials and use PMAs?
Very good suggestion Idan. Getting a PMA is most likely a lot easier than CRN.
Huub
- You never get what you expect, you only get what you inspect.
