Pdnorenberg
I am trying to find a way to fill and empty a ballast system on a boat without using any type of pumps. By using an underwater intake the ballast tanks are easy to fill by simply driving the boat at high speeds, forcing the water into the tanks. However, I was trying to find a way that I could use rushing water to create air pressure or suction that would make it easy to empty the tanks quickly and efficiently. If you could give me any basic ideas to experiement with it would be a big help. Thank you.
