abrewmaster
- Aug 15, 2013
- 20
I am trying to figure out a way to call out a center plane as a datum to a molded part that has only drafted faces to reference.
I understand that it is possible to call out a center plane as a datum using a width dimension as shown in the attachment but I am trying to figure out if this is still the case if the surfaces are drafted.
The main issue I see with this is that then you are dimensioning from edge to edge, not surface to surface. Or is this not an issue if you still call out a perpendicularity to datum A (in the attachment).
