stonehentsch
Hello everybody,
I have two plates resting on each other and at some point the upper one slides along the touching surface of the lower plate. I want to define a constraint that forbids a certain point on the upper plate to leave a certain area on the lower plate. i cant use the connector slide plane because the lower plate is moving as well.
thanks in advance
thanks in advance
