AlexWong122
Hi there,
I am designing a header in exterior wall (2x6 stud wall) and due to the large snow load, my factored reaction force at one end of the header is about 30 kips. The head is 5 1/4" x 11 7/8" PSL beam and I would like to 5 1/2" x 7" PSL post, but I am worried about bearing capacity of the sill plate (typically it is SPF material and I will need 9" bearing length in this case). I have two questions:
1. Does it matter that if the sill plate crashes? Is there any simple way to increase the bearing area at the bottom of the PSL post?
2. If I am going to use build-up post for this header (for the purpose of increasing the bearing length), I will need 7-2x6. Is it possible? I remember I heard someone saying to limit the build-up post to 5 piles but I can't find the reference.
Thanks in advance for your inputs.
Alex
Alex
