SinanMaimar
- Sep 21, 2011
- 3
There is a fairly large attachment to this long post including several pictures, a partial plan and a partial elevation view. It’s an existing 4 story structure from 1950s with load bearing brick walls and concrete on bar joist framing.
There are two locations of significant cracking within the existing masonry along the west elevation of this building. This attachment shows cracking along at the south end. There is similar cracking at almost identical mirror location to the north. My goal is to determine the cause/causes of the cracking and suggest a repair procedure.
To summarize the pictures:
Existing walls are 16” multiwythe brick. This story is a partial basement. And I guess this would be my first question: I can’t tell from the drawings if the brick continues below grade. Was use of brick as basement or foundation wall ever practiced? I am wondering if below grade (on the exterior face) the brick is replaced with cmu or even concrete. The gap between existing ceiling and wall (pic 2 & 4) indicates movement of the walls to the outside at the top. The wall is bowing in at the crack location (pic#1).
I did not see any expansion joints along the whole elevation and I wonder if the cracking is partially due to that.
There is also evidence of water infiltration at the roof level and I believe that is a contributing factor.
Caulking within the cracks at the exterior suggests that this cracking has been around for a while.
I have other pictures but did not want to post a very large attachment. Obviously I am requesting some insight from the participants here to help me out a bit.
