numberfive
Experts,
We have been asked to perform welded repairs on a deaerator vessel built in 1948. The vessel shell and head material is listed as "Copper Bearing Steel", no ASTM or ASME specification is given.
Aren't copper bearing steels typically used in outdoor weathering applications? (ie: corten or A588)
Has anyone ever seen this used in a pressure vessel application?
I would like to perform the repairs using our P1 to P1 combination tig, stick, & flux-core WPS using ER70S-2, E7018, & E71T-1M. I understand that sometimes the HSLA weathering steels are welded with a higher grade filler metal but in this application I don't see the need for it.
All nozzles are listed as A106 Gr. A.
Any input would be greatly appreciated.
numberfive
numberfive
