Is there an acceptable practice to control runout (axial location) of a feature-set separately from the form of the feature-set (which is controlled on another print)?
On this print, essentially, what I want to convey is:
Here's what I came up with - I just wanted to get some feedback on whether or not the intent is clear, and if you think this is an acceptable depiction of the requirements as described.
*Our drafting standard for the most part adheres to ASME requirements - Y14.5M-2009, Y14.100 (*our flags are special...), etc.
The background:
I have two prints: a machined part print, and a print which describes a modular feature-set used on the machined part.
This common feature-set (colloquially known as "the profile") is used on multiple parts.
Since each profile feature-set may be used on 1,000's of prints, we keep all dimensions relating to the profiles on their own prints for purposes of maintenance and consistency.
The profile print itself controls the form of the profile feature-set (profile of a surface tolerance of .002").
This is inspected using a contour tracer, which historically has worked very well and I'm told is within an acceptable limit for capability.
The profile has a tight tolerance because it has to fit with a mating part, however the location of the profile feature-set is determined ad-hoc for each application.
For this application, we want to control the runout of the profile in relation to another feature of the part. The entire profile can be allowed to runout by up to .020" and the assembly will function as intended.
THE FORM OF ALL FEATURES FROM POINT X TO POINT Y IS CONTROLLED BY PRINT 109-2367
THE LOCATION OF ALL FEATURES FROM POINT X TO POINT Y IS CONTROLLED BY THE RUNOUT TOLERANCE ON THIS PRINT
The background:
