I have a 24.5' x 64' section of slab on grade (10") that I have joints: 1 vertical and 1 hor. cutting the slab into 4 sections each 12.5 x 32 roughly. the architect has floor drains in the middle of the 24.5x64 section and the slab sloping to the drains. they want joints coming from each corner on the diagonal to the opposite corner. these would be in addition to the ones I already have. now the slab is a bunch of triangles.
my questions are?
1. is there concern for the size of the slab points where they call meet at the drain. it's a drain with 8 joints coming in to it. one top and bottom. one left and right. and one at each diagonal
2. it is a drain so i thought about using a diamond control joint pattern, similar to the base of a column, to move the joints away slightly.
3. since the slab is sloping to the middle, I really don't think I can cut this up any other way?
my questions are?
