EngMan40
- Jan 11, 2009
- 66
I have multi-span beam that is fixed on one end and is supported on 4 spring supports: |------3-----3-----3----3 the beam is not on ground. I want to analyze this beam with K value of the beam is known. Is there a theory or procedure to know the reactions and displacements of the springs for statically indeterminate beams, load is hydrau-static with maximum at fixed end.
