Hello Prym,
The first thing I noticed was that regarding the contact surfaces for the pin the surfaces selected were the non contacting surfaces. That was the first fix.
I was experiencing the same difficulties trying to mesh the part but just accepting the default selections in the AutoGEM dialog box. However, it would be best for this particular application to mesh the volumes seperately. To do this you will need to perform the following steps:
1) From the AutoGEM dialog box choose the drop down selection "Component volumes".
2) Next, select the pin then click the middle mouse button to accept.
3) When the AutoGEM dialog box comes back click the "Create" button on the right. The mesh for the pin only will be created. Click "Ok" on the statistics box and return to the AutoGEM dialog box.
4) Reselect component volumes again by clicking the arrow, but select the ring only this time.
5) After returning to the AutoGEM dialog box click the "create" button and the mesh for the ring will now be created.
6) Click "close" to exit the AutoGEM dialog box. Don't forget to save your mesh so that you can explicity tell Mechanica to use your generated mesh and not try to create a new one.
This should all work now.
Hope this helps.
Steve
Stephen Seymour, PE
Seymour Engineering & Consulting Group
