I had a post quite recently concerning to find strain energy release in dent growth induced by buckling, I have problems running that/finding a way to get the rates so I am trying another approach with spring elements, SPRING1.
They actually comply alot better with existing theory. Anyway,
In my cofiguration I must have a quite dense mesh to be able to get values as simulating the dent growing, so therefore I use an orphan mesh and then connect the SPRING1 elements to the nodes, now using bias seeding each element as a different area.. would I have to define a K (N/m) for each one of the springs or how does it work?
Also, how is the area the spring ''covers'' defined - 1 spring to 1 element- ?
Hmm quite unclear in the doc.
Thank you very much for your consideration // Jon
