Well, I post now the interaction diagram based in the unreduced characteristic strengths of both the steel and concrete, and full section of 24 inches total width as effective. It is NOT an interaction diagram for the immediate check of structural members along any code, since the worksheet giving the values in compatibility of deformations is one targeted more to ability to meet some solicitations in accord of the science of construction and mathematics than any code. This said, and for the given section, these capacities (and higher, giving that the average strengths of the steel and concrete will be higher) should be expected of the section of the member.
One likely difference with the two interaction charts of staffengw and IDS is that in this chart, the strain hardening of the steel is taken unto account, what results in some points showing tensile stresses exceeding 60 ksi. This happens mainly in the low range of axial loads.
The chart has been built searching with the help of the worksheets points for which equilibrium of moments and forces are met that pertain to the interaction chart. A Pn is tried, then we try to get the true maximum Mn available for the section meeting equilibrium, this in 10 kips steps.
The mathematical procedures, even trying to find a maximum, fail many times (without manual iteration) to find in a single try the Mn to port at the chart. This because there are local maxima that are accepted as solutions. Seeing the chart, the two flattened parts in the bottom part of the curve quite likely will get a more continuous curve by just making some trials more that give a more true (and higher) Mn acceptable as concomitant with the trial Pn.
Since my chart and the one from IDS show what seems to me reasonable continuity, I am as IDS of the opinion of that the actual chart shouldn't be showing the discontinuities shown in the one causing staffengw question.
Of course if you take a true interaction chart for a member like ours and then deviate inwards the safe zone we can still have a safe interaction chart. The algorithms used, or error, may lead to this happen and as long you are satisfactorily convinced that there are no other outwards satisfactory values, one could take it as a true axial-moment interaction chart. As said, the algorithm, or an insufficient number of trials may make this happen.
