Concrete Discoloration (Blue-Grey) 2
Is it just residue on the surface? Was this surface previously in contact with the subgrade and is that subgrade that color?
Otherwise, when you chip away at that blue-gray surface do you find more blue-gray beneath?
faq731-376
Yes.... likely slag cement mixed with portland cement. Commonly done.
Gives a blue-gray color that will change to gray upon long term exposure to air. Not a concern unless there are other issues.
You can see in the photo that the upper part of the section has already oxidized and at a point below where the section was in contact with the ground, the change has not yet occurred.
