It was probably built for the cool storage of vegetables and root crops, so they were available for long periods. It was very common since help maintain a fairly uniform temperature and relative humidity in cooler climates.
Similar construction is the FEMA requirements for "safe cells". Usually, the design recommended is to use a reinforced 8" concrete slab supported by either 8" reinforced concrete walls or 8" reinforced concrete block walls. The criteria is to provide protection from debris and projectiles with no penetration since it is a life safety issue. The recommendations are based on many years of actual testing at a Texas University. These recommendations apply for "safe cells" within a structure (below or above grade) or for remote structures that are buried or partially buried. Obviously, it is not practical to design individual cells from from a structural standpoint, so the engineers used a performance-based criteria for individual elements. AS far as debris, whatever goes up, comes down, either vertically or horizontally.
Your 10" slab should be adequate, but the amount of reinforcement is unknown, but the 8' spans are short. The question is what are the materials for walls? It is not a typical structural design. since no codes really apply and proven performance is the key for a once in a lifetime event.
Because the FEMA standards are based on life-safety, they contain very specific details that are somewhat unusual. One key item is that the steel door should open into the room to allow egress in the case of a collapse of the adjoining structure.
Search for "safe cell" on the FEMA site for some very interesting study.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
