jpx
- Nov 2, 2009
- 9
I'm no expert at compressible fluid systems, but I ended up being the one to design it...
I'm having trouble calculating the required pressure to get the desired volume flow rate (at outlet conditions).
The system must feed helium vertically through 3/8" ID, 112 ft long tubing (ID can vary, I just chose 3/8" for the availability of very lightweight tubing). The desired flow rate is 100 ft3/min or greater (Outlet Pressure = 0.1083 psig).
So far, I have used Fanno Flow equations and found an inlet pressure of about 1.9 psig. The flow rate here came out to about 100 ft3/min. Does this pressure make sense? It seems a bit low to me...
I was hoping this would be a really simple system for someone here. Any advice or help would be greatly appreciated, Thanks.
