CompactLogix: how to change the IP in MSG? SSV?
rssql
Industrial
May 17, 2004
7
I have a CompactLogix L32E.
I want to use the MSG instruction with more than one IP address.
so, i need to change the IP address/path in the MSG.
I haven't been able to find an example.
Would i use SSV?
Thanks,
I want to leave the IP of the Eth port as is.
I just want to change which device i communicate with.
Simple solution:
Use two or more message instructions, one for each target device.
I can't create one MSG for each destination.
That could end up being 50 to 100 IP's.
thanks,
