hrcooper
- Aug 31, 2011
- 36
OK..now that I can download the program to the Panelview (had to use a AB CF card for that)
Hardware is the ML1400, the Panelview1000 2711-T10C3, and a 1767-AIC unit.
The ML has CH0 for the programming port, CH1 is ethernet and the DB9 is CH2. I connected from the DB9 to either the DB9 or the circular mini (with external power to the AIC). I connected from the AIC to the PV1000 using a RJ45, thru the terminal block. The wiring is RJ45.1 to TB.3(A), RJ45.2 to TB.4(B) and RJ45.6 to TB.6 (chassis ground). Autobaud is selected.
The TX green LEDs for both the DB9 and the terminal block are flashing. They stop flashing when I pull the terminal block so it seems as if its trying to communicate.
In RSlogix500, under channel states for channel 2 im just getting bad packets/sent NAKs but no other traffic.
The PV1000 comm LED is flashing (meaning comm error I assume) and setting a different node doesnt seem to affect it in the DH-485 setup screen.
RSlinx doesnt see anything on the network but not sure it can "see" thru the ML1400 or not.
So...what am I doing wrong..is it a setup problem, connection/wiring problem? This has been just a nightmare project and its not over yet.
