I have a MeOH stripping column, with reboiler heated by steam. Overhead vapor is condensed in downstream condenser. At shutdown the feeds and steam are shutoff.
Question is how to handle inbreathing if the condenser is left on. At first glance, it would appear that I should treat the column as a "steam out case" and assume the condenser is not working. I am questioning the impact of the condenser. On one hand it could increase thermal inbreathing by reducing the volume of vapor in the column; on the other hand, removing the vapor might be a good thing.
The Plant ran a trial late last week, taking the system down and no change in pressure was observed.
Any thoughts?
Any thoughts?
