It is said that bigger columns attract greater earthquake forces. Imagine a column that is size 0.3x0.3 mtr versus one size 0.6x0.6 meter and 3 meters height each. The earthquake would produce the same displacement and the 0.6x0.6 meter column would be stiff hence attract greater seismic forces. This is the basis of the captive or short column above window effect. Now. When you guys design columns. How much do you take this into account? Are you so conscious of this that you put much more ties in columns for bigger columns to counter the stiffness factor during earthquake? I'm asking this because I have columns size 0.4x0.5. I wonder whether to make it 0.5x0.5 or even 0.6x0.6. Is the stiff factor linear or exponential to the column sizes? Although extension shear analysis can show it. Any rule of thumb estimate of the relationship of stiffness factor and shear for seismic lateral movement?
