We are working at a condominium along a beach. Reinforcing a pool deck that has seen far too much corrosion from the elements. The pool deck intersects with the main building at a balcony. We have to replace the balcony spandrel beam, but want to avoid replacing the balcony columns as they support other spandrels, and an interior girder for 4 stories and a roof. Our first thought was to just grind back to bare metal and cover plate, even if it needed to be on all four sides. However, we got started grinding back to bare metal and found that the flanges are fairly thinned out and the web is corroded completely through in some locations.
The question is - should we cut our loses and replace the column? Does someone have any other ideas for reinforcing that would develope into what is left of the exist column.
See the attached picture.
Thanks,
Andy
Thanks,
Andy
