Hokie93
- Sep 9, 2007
- 375
I am seeking opinions as to whether the provisions of ACI 318-11 12.14.2.3 can be applied to a column member that is solely in compression. ACI 318-11 12.14.2.3 states:
Bars spliced by nonontact lap splices in flexural members shall not be spaced transversely farther apart than the smaller of one-fifth the required lap splice length, and 6".
I have a situation where the dowel bars at the base of a cast-in-place concrete column need to be offset from the column longitudinal bars by approximately 3 inches. The fact that 12.14.2.3 specifically indicates noncontact lap splices are permitted in "flexural members" is giving me pause. I would not typically classify a column subject solely to compression as being a flexural member. I checked ACI 318 back to the 1989 version and the requirement is unchanged.
