broncosfan
I have a steel framed building with braced frames. On the frame lines, I have wide flange girders supporting joists spaced at 6' o.c. The wide flange girders are acting as collectors and support an axial force. Looking at the weak axis of these wide flange collectors in compression, what should I use as their unbraced length... the length of the beam or the spacing of the joists? The joists are only attached at the top flange. Do they indirectly also brace the whole beam to some extent. Is it too conservative to say that the beam is totally unbraced in it's weak axis because the joists only brace the top flange?
