RotorLiftKiowa
Aerospace
Say you have an aluminum part made from 7050-T7451 material and you need to cold work a hole and shot peen the part (the hole will be plugged so that it doesn't get peened). We are wondering which step should be performed first.
I'm inclined to say that one should first cold work the hole and then shot peen the part afterwards because the shot peening would assure you that the surface around the hole is in compression. Otherwise, if you shot peened the part first and then cold worked the hole you would still likely have a circular tensile layer around the hole even at the surface and that would be a negative because cracks would want to initiate there.
What are your thoughts on this?
