roberto1brazil
Hello everybody !
Please, could someone help me with this following issue?
At my job we have a part to be inspected applying best fit to the datum. Below I describe the machine caracteristics and the sequence of the process. Our doubt is how to apply the function best fit on the pins using the software of the machine. Our operator is not familiar with this command, Would be possible to give us an idea of how and where to input the data? I have attached a drawing in order to clarify the question.
Thanks to all.
CMM MACHINE MODEL – DEA 07-10-07
CMM Software – PC DMIS 4.3 MR2
Aim : To obtain the offset (out of position) of the three diameters A, B and C in relation to the Datum D
Datum D : Is defined by the six pins on plane X.
Do not consider any perpendicular’s geometric offset
Steps (described in the process):
Creation of measurement reference K (marker K)
Main reference: Probe the X plane at 12 points evenly distributed over the indicated face.
Secondary reference: Probe circle DB at 12 points evenly distributed over the diameter in the half of height H.
Tertiary reference: Probe circle DA at 12 points evenly distributed over the diameter in the half of height H.
Optimization of Marker K
-Create theoretical points PT1 to PT6 in the plane X.
-Probe circles PP1 to PP6 at 4 points evenly distributed on the pins circular surface.
-Perform a “Best Fit” on points PT1 to PT6 of marker K with respect to the center of circles PP1 to PP6.
Measurement:
-Probe DC at 12 points evenly distributed over the diameter in the half of height H.
Post processing:
-Create theoretical points DTB, DTA and DTC in plane X.
-Determine the distance from DTB to the center of circle DB.
-Determine the distance from DTA to the center of circle DA
-Determine the distance from DTC to the center of circle DC.
