mariovalenti
We are doing a maintaning of an air-colled heat exchanger, which had been working in a oil refinery for years.
It have 11 meters length, a width of 3,5 meters and 370 tubes (1" diameter x 1,7 mm of thickness -1/16"-).
The tubes and heads are very dirty with residual oil and organic deposits stuck to the walls of the tubes.
Due to this it have a loss of efficiency (low heat exchange and loss of pressure in the piping).
We think to do an internal cleaning using a mixing of Soduim Hidroxide (soda)with water to remove the dirt and oil.
Is somebody able to tell me if this process is adapted to do that (the steel of tubes is SA179 and heads steel is SA516)?
What proportion soda-water (dilution) is correct?
How much time can we mantain this solution into the tubes/heads?
Thank you in advance.
Mario Valenti
Mario Valenti
