circular pattern on a cylindrical surface
What version of NX is this ?
Select the Pattern feature, select the hole, specify Circular as the "layout", select one of the cylindrical faces for centerline/vector definition,
and...
Tomas
It could work if I specify "along vector" then select a circular edge.
Is it possible to upload an example ?
Tomas
I think this will work but I can not guarantee it (I am using NX12.0):
[ul]
[li]Make a curve around the cylinder. For example you can use a plane and intersection curve.[/li]
[li]Make a sketch on that curve.[/li]
[li]Make several points where you want the holes using pattern curve (in the sketch).[/li]
[li]Select the sketch for the hole feature, or select each point individually.[/li]
[/ul]
I hope that helps.
