Circular pattern curves without rotation
RhysMog
GB
Can anyone tell me if there is a way to create a circular pattern from a set of curves that does not require the curves themselves to rotate? Basically I want to translate a rectangle to 36 points around a circle (10 degrees apart) without changing the angle of the rectangle's sides. I have to do this hundreds of times, so this would be a real time saver!
Thanks for the reply cowski. Is that option under pattern curve, elsewhere in sketcher or somewhere entirely different? I have so far been using Edit > Move Object to create copies of the curves, but "same as input" isn't contained in there...
Is this available in NX7.5? I probably should have mentioned my version beforehand...
NO.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
