I work for a firm which supplies material and labor for projects through out the Midwest. This requires us to prepare shop drawings, which consist of erection drawings and fabrication drawings.
It has become very common for the type of material we supply to see specificatons which require the submital of certified shop drawings. Some specifications will require that all shop drawings be certified and others will only require certification of shop drawings for certain materials and not for other materials like the structural steel.
Regarding the above practice the engineers on our staff have raised a number of questions.The first question that comes up is what is it that we are being asked to provide certification for?
A simple example is on a project where we supplied a panel product. The panel size, strength and fastening requirements were all specified by the EOR. Our shop drawings which were required to be certified consisted of a panel layout sheet & material list.
The registered engineers on our staff, myself included, are familiar with the concept of certifing that a design was prepared by or under the direct supervsion of a register enginner. However we are left wondering what it is that requires certfication; when the shop drawings consist of a structural plan, provided by the EOR, which we have added mark numbers to the material and provided a material list which shows quanity and size of members.
I know the above examples over simpilfy the problem. However we did have one project where we were required to submit a certified design for one detail which consisted of a standard product with known properties selected from a manufacture's catalog.
My general feeling is that some engineers are trying to subsitute our shop drawings for structural drawings to cover elements of the project which they had not designed. We do not have a problem with submitng certified design calculation or certified design drawings. It is the certfcation of shop drawing that we have a problem with.
What do you think?
There are a lot of issues surrounding this question. One example I dealt with was on an assembly where the shape, member size, fastener size and number were specified by the EOR. The only thing not specified was the fastner spacing, which were all governed by code requirements. However the specifications still required us to submit a certified design for the assembly.
The major question raised in this case was that an engineer certifing the assembly design would be required to state that the design was prepared by, himself or under his direct supervision. I felt that the EOR was asking for certification of his own design by another engineer. which would be prohibited under the governing state requirements.
What do you think?
