Sorry to mess you about but further correction to stagger now 19 degrees after more accurate measuring of aircraft already rigged, and redrawing to scale.
Thank you all for you for your further notes, I had looked to some of these sites but the formula are far beyond my capabilities.
I have constructed a 1917 Albatros D5 replica homebuilt to spar with my SE5A replica(built to plans 35 years ago) I am test flying the Albatros at present. Flights have been short, 3-5 sec, as my strip is only 340 metres long, so have wait for a favourable breeze.
The C/L and CofG relationship have been calculated by a knowledgeable but not qualified person (who has just designed and built a gyrocopter)
The aircraft is controllable in flight but drops the nose when the throttle is closed.
I suspect the CofG is too far forward as I run out of elevator even at 50 degrees up. Tail plane is on a jack but does not help. Wings are set at zero incidence.
Before I start shifting the CofG I need to know for certain where the C/L is,calculated by a qualified person for biplanes.
I understand these persons are scarce as sesquiplane design went out of fashion a long time ago.
Another reference that I have viewed is "relative loading on Biplane wings of unequal chords" Diehl, Walter S. This was written about 1934 but is beyond me.
In anticipation of happier landings!
